-   -   HV-110 Phoenix ESC Question (https://www.rc-monster.com/forum/showthread.php?t=12309)
adrenaline 05.23.2008 03:42 PM
Hey Guys,
I've built a DM-One using a Neu 1515/1d, 4S 14.8v, and a HV-110 ESC. I'm getting 7 light blinks on the ESC in neutral only. My manual only shows upto 5 blinks. Does anyone have an idea what 7 blinks translate too?
Thanks,
Al
MetalMan 05.23.2008 03:45 PM
So this means that you are programming through the TX, right? I've never programmed my HV-110 through the TX except for endpoints (if even that, I might be using the auto-endpoint setup). All programming I've done is through Castle Link. Is that an option for you?
lincpimp 05.23.2008 04:14 PM
Yep, castle link is the way to go. Only prog I have ever done thru the transmitter is for endpoints on a MM. I have the cc85hv but have not got around to using it yet. If you do not have the castle link and feel like a drive to the northshore you can borrow mine!
Are you using a pix stix adapter?
BrianG 05.23.2008 04:28 PM
I think he means he's getting 7 blinks when running, not programming, but that doesn't make any sense. If it was in program mode, you'd also hear the little chirps...
MetalMan 05.23.2008 11:48 PM
7 blinks when running? Only thing I can think of that might do that would be auto lipo cutoff (if it isn't doing it in programming mode). In which case a set LVC voltage would remedy that.
