How do I check if li-po batts still good after sitting for almost a year
What is the easiest way to check to see if the batts are still good. I believe I charged them before putting them away...can't remember. I tried to charge them and they only took 50 mah on a 1500mah 3s pack. Unfortunately, I don't have a vehicle to run them in to check them. My friend wants to buy them, but I cannot sell them to him in good faith w/ out seeing if they are still good.
If you discharge them down to 3v per cell and check how far it charges before it tops out that should give you a good indication of the packs condition.
| All times are GMT -4. The time now is 02:22 AM. |
