Holes in Your Tires?
What do you guys use to drill holes in your tires to let dirt and water get out? I've never done it before and just got some new tires. Do you just bust out the drill and go for it or is there some technique someone can point me to? Thanks!
You run the risk of tearing the rubber or getting non-uniform holes if you use a drill.
I use a leather punch tool, like this: http://www.amazon.com/eToolscity-TAI.../dp/B0002T87FE I picked mine up from Home Depot and it's almost identical to the one in the link. Works very well and punches nice round holes. |
Well, that would work if I didn't buy pre-mounts. :neutral:
I tried this once on a set of stampede talons and it was a disaster.
I just took a 3mm drill too them - sadly when running on brushless power I managed to get a whole foam out through one 3mm hole. On the other tire it ripped to shreds! I obviously did it very wrong and am interested to see how to do it right. Proceed with care though! |
I still say tires should be sealed and air filled just like real tires. Sure, makes them a bit bouncier, but nothing that can't be dialed out via suspension tweaks I would think.
How does it hold up?
I've had good luck using a drill bit in a dremel tool. It spins fast enought to melt through it rather than tear it.
I imagine it would be heavier. Hmmm. Maybe get rid of the tube for a belted radial? And use a different solution instead of a valve stem?
1 Attachment(s)
Found it, but I can't find the other ones. I will have to find the pictures that I printed and scan them.
Wow, 1.1lb per tire??!! They are bigger than normal at 6.5" D X 4" W, but still. The rims look like Al, maybe a high grade plastic would be better. Wonder how heavy a typical on-orad, buggy, or MT/truggy tire would be...
I have some 40 series tires that weigh about 1 lb.
fastrax make this tool
http://www.rceasy.com/wp-content/upl...04/fast605.jpg Make quick and easy air holes in your tyres with with this new purpose designed tool from Fastrax. Its special inwardly rotating barrel allows pressure to be applied while the cutting tip cuts through the tyre wall producing perfect holes every time http://www.rceasy.com/wp-content/upl...4/fast605a.jpg |
| All times are GMT -4. The time now is 03:12 PM. |
