Nikon D60 or D80?
how would you rate your camera expierence and the application of the camera...my guess is that since you are asking our opinion is that you are not too sure yourself if you must stay with Nikon I would go with the 60 model ...it seems like the 80 has a few more bells and whistles you dont need. I am a Canon man myself and I have a 10mega Digital Rebel that I am very happy with, and over 1/2 the stuff I dont use...and I dont have to buy the Canon lenses Quantum makes compatable lenses for about 1/2 the price |
I was disappointed in Nikon when I started having trouble with the battery door on my 990 (cost almost a grand when I bought it). The little housing the batt door finger went into broke off and after repairing it (CA) a few times, it was no good. They basically told me it was time for a new camera, they wouldn't help.
After many, many years as a Nikon owner, I bought a Canon. Been very happy with it too. |
The D300 if you can afford it with a nice DX VR lens.
Assuming you are here in the states make sure that no matter what you get you get it with the US warranty and not the grey market products with international warranties - it's not worth the 50 dollars of savings. This is one of my favorite sites for digital camera reviews: www.dpreview.com Also for purchases: www.adorama.com or www.bhphotovideo.com They are two huge stores out of NYC that have been around forever. |
I've had my eyes on the D80 for a while. It seems like what you get over the D60 is worth paying the extra for, at least considering what I want to use it for.
If you're going for action shots then the D80 is a must. It's all about responsiveness, and the D80 kills the D60 on that front. If you're just doing artsy still shots, then the camera doesn't matter as much as the lense, because once you get into the D-SLR territory, the most important features for still photography are usually included. http://www.beachcamera.com/shop/home.aspx |
Made an external batt pack and hard wired it into camera body and velcroed the pac to the other side of the camera. Worked, but balance and grip was odd, made it harder to use and it looked like heck. Just needed a new body. Very poor design, Had the same thing happen to my wife's Nikon too, another batt door prob. The location of the shutter was moved on the her Nikon and its is still working with three hvy rubber bands across the batt compartment. Fell out of favor to a pink Kodak however..... Canon's design uses a purpose built batt and a little internal catch to hold it, there is no pressure on the door and the catch the way its used has little pressure either. My last camera store camera was a Nikon FE SLR, everything since has been online from a store in NY. |
What package do you think is better?
http://photodynasty.com/catalog/prod...ducts_id=6689& http://photodynasty.com/catalog/prod...d70db9ab2bee70 |
Don't go there - There is no physcial adress for that store - If you see a really cheap deal for a bunch of shops in brooklyn they are not worth it. A bunch of con shops...
if this is your first expensive camera (digital SLR) you might want to buy from a camera store, you will have more resources and piece of mind untill you have more expierence ...my wife bought my Digital rebel XTI from Ritz
Don't buy from those links. It is a scam. You will get a phone call a few days later with someone trying to strongarm you into buying tons of accessories and they will tell you the camera is not in stock when you don't buy them. Either that or you will get not what you ordered and trying to return it will be a truely painful experience if you can.
Pay the extra few hundred and buy from a reputable dealer. And also - ALWAYS BUY WITH USA WARRANTY - I can not stress this enough. The two I mentioned above are reputable, also consider J&R Music World as well. Here is the one you linked to with the 18-135mm lens. http://www.adorama.com/INKD80K2.html Also - keep in mind that when you are buying a digital-SLR camera, you are still buying a camera lens whose focal length is rated in regards to a 35mm film camera, so there is some conversion to be done. That dpreview.com site I gave you a link to usually provides the information that will look something like this (1.5x FOV crop). What this means is that a DX sensor is only 24mm compared with a full (or FX) sensor or 35mm film slide which is 35 mm wide, so when the image comes through the lens the digital sensor is only seeing 66% of what a full 35mm sensor would see. In order to get the DX relative focal range of the lens or zoom lens you need to multiply the focal length by the FOV crop - which in the case of most SLR cameras is 1.5x (although some Canons are 1.6). In standard 35mm film photography a 50mm lens was considered the standard for a 1:1 picture. Lower was wider angle and higher was narrower angle (ie: zoom). For the 18-135mm zoom lens, the DX equivalent you would have would be 18x1.5 - 135x1.5 = [27 - 202.5mm] The 28 - 200mm zoom lens would a DX equiv. of 42 - 300mm. You actually would not be too happy with this as a primary lens because you would not be able to zoom out much past the 1:1 50mm length. I would recommend the 18-135 as a very good all around lens to start off with. |
Don't buy from those links. It is a scam. You will get a phone call a few days later with someone trying to strongarm you into buying tons of accessories and they will tell you the camera is not in stock when you don't buy them. Either that or you will get not what you ordered and trying to return it will be a truely painful experience if you can. If a camera and lens cost $900-$1000 everywhere else and you see it somewhere for $500 doesn't a red flag go off somewhere? |
FYI - I'm not trying to be a d**k either to you, just trying to prevent you from losing your money. Please see this link:
http://thoughts-of-dave.blogspot.com...eviews-on.html |
| All times are GMT -4. The time now is 01:41 AM. |
