-   -   Spur gear size question (https://www.rc-monster.com/forum/showthread.php?t=12558)
VintageMA 06.04.2008 08:51 AM
Can anyone tell me if the size of the spur gear really matters?
Aside from varied gearing options, is their any really noticeable effect of using a 44T versus a 48T in a 1/8 buggy?
I was reading the specs of the new Hyper 9 and it says:
The buggy accelerates and has greater top end speed because of the 11/43 gear combination at the front/rear gear boxes and the 13/40 combination at the center differential. The faster spinning center differential also reduces the torque effect of the engine.
http://www.nitrohouse.com/details_hyper_9.htm
I know the new xray 808 went in this same gearing direction too.
Arct1k 06.04.2008 09:12 AM
Smaller spur enables lower COG and would hold less momentum and hence be easier / quicker to spool up - thats all I can think of
VintageMA 06.04.2008 10:24 AM
I guess the question I am really asking is that if I am running 15/48 (3.2) right now will I see any benefit of going to 14/44 (3.14)?
Arct1k 06.04.2008 10:26 AM
You will go a touch slower with perhaps a touch faster accel but none really that I can see...
Spur won't dip in to the chassis so less change of kicking up a rock... if thats an issue for you
VintageMA 06.04.2008 10:36 AM
Yeah - kinda what I though - thanks.
