-   -   pinion lube (https://www.rc-monster.com/forum/showthread.php?t=12618)
droopy 06.05.2008 09:11 PM
pinion lube
Hey my X1-CRT is just about ready to roll but im wondering with running the stock spur (which is metal) and my hardened metal pinion from Mike should I run some open gear lube on my gears?? or will they be just fine dry??
BrianG 06.05.2008 09:23 PM
I've never lubed them and they're fine. And as a matter of fact, running lube might be bad because dust/dirt will probably stick to it acting like sandpaper to the gears.
rschoi_75 06.05.2008 09:30 PM
I use this:
http://www3.towerhobbies.com/cgi-bin...?&I=LXDH62&P=7
droopy 06.05.2008 10:10 PM
I think ill try it without anything on them and check temps if there high ill try some dry lube .
jhautz 06.06.2008 12:55 AM
ANother prooduct that works good on metal to metal contact surfaces that are exposed to dirt is called Dri-Slide
You can get it at mcmaster.com in a 40z squeeze bottle for around $10. Its a little messy, but ti is fantastic dry lube that doesnt attract dirt. It actually repels dirt and its designed for high pressure, high temp appications. I use it on spur and pinion and in diff cups and dogbone ends.
I'd post a link but mcmaster.com is based on a pdf catalog it wont work. Just go there and search dri-slide and get the 4oz squeeze bottle. Thats plenty for a long time.
But in reality, you really dont need it. I just like to take as much friction out of the driveline as I can.
