-   -   Anyone tried Dual Mamba 4600's on the New Maxx? (https://www.rc-monster.com/forum/showthread.php?t=12651)
sikeston34m 06.07.2008 10:19 PM
I just picked up a Pair of Mamba Max ESC's and a brand new pair of MM 4600 motors.
I'm wondering if anyone has tried this?
What kind of gearing should I go with?
I'm thinking about running it on a pair of 3S 5000mah 20C Lipos. 4S maybe, but motor temps will be hard to control. 4S is a bit much for the motors from what I hear.
A pair of heat sink fan clamps for the motors. A fan mounted on each ESC will help.
Can't forget the CC BEC to run all the fan and servos with. Let's set that to 6 volts. :yes:
johnrobholmes 06.07.2008 10:21 PM
Do the motors have the newer 4mm plugs? I heard that the rotor was getting an upgrade too but I don't know when that happens.
sikeston34m 06.07.2008 10:37 PM
These plugs looks like all the other MM plugs.
I just realized about the length of motor shaft issue with the New E maxx.
The motor shaft has to be 20mm in length to line up perfectly with the end of the pinion gear. These are 17mm in length.
Hmmmmmmm...........I also have a Traxxas Villain Boat these might work well in. :yes:
skellyo 06.08.2008 10:02 AM
FWIW, 2 new 4600's I just bought have the new Castle 4mm plugs.
suicideneil 06.08.2008 11:45 AM
This might help:
SSSPConcepts
Thread:
Clicky
