my mmm is working but where is the USB
ok where is the usb plug on this MMM?
so far it is working but brakes HAVE to be adj before i do an endo. |
you should have gotten an adapter with a usb on one end and the other end plugs into the plug that plugs into your receiver. If that was a little too confusing...unplug the esc from your receiver and plug it into the adapter cable. There is no actual usb on the MMM itself, you have to use the adapter.
Hope that helps, maybe someone else can explain it better if not. |
it uses the Castlelink like the Mamba 25 does
link....http://www.impaktrc.com/product_info...oducts_id=2374 but one should have come with your MMM |
You can read about the Castle Link on the CC site http://www.castlecreations.com/produ...stle_link.html
i figured that but the 2 plugs didnt fit togeather without grinding that tab off.. have to put my reading glasses on.lol/ thanks
hey reading glasses work.LOL i was removing my steering servo plug .(dumb) heat stroke .LOL
While we're on the basic subject, can i use that same adapter to set my CCBEC to run at 6v instead of 5.1v?:tongue:
I would imagine so, as long as you can change it from a PC.
it wont enter manual programing mode either . hold full throttle and turn on thing. ill update software tonight and report back.
fixed. update did the trick
id imagine you would only have to unsolder one? glad to know (i just assumed that this was the case)
| All times are GMT -4. The time now is 10:09 AM. |
