batteries batteries
ok say i was wanting to make 36volts in an electric motorcycle. I was wondering wether three 12volt car bateries would last longer than 30 nimhs with a 600 watt motor and a 36 amp controller. So Witch batteries would get me more miles and last longer. thanks
Anyone considered weight? 3 regular sized car batts would weight close to 60 lbs?!?!
I would go with a123 cells, at least 10 in series, and maybe 3-5 in parallel, so 30-50 cells total. |
A123 wouldbe nice, However 50 cells is 500.00 You can get 3 deep cycles for 150.00 So like they say how much do you want to spend.
highflier |
And with car batteries, you can apply a constant trickle charge without hurting them, whereas any Li chemistry wants to see at the very least a CC charge with a voltage limit - ideally, a CC charge ending with a CV "top-off".
| All times are GMT -4. The time now is 12:18 AM. |
