-   -   batery amps (https://www.rc-monster.com/forum/showthread.php?t=12711)
jlustig83 06.10.2008 10:14 PM
batery amps
would 10 nimhs have more amps than a 12volt car battery . i dont know which one would last longer in an electric motor cycle
jlustig83 06.10.2008 10:17 PM
oh and the motor is only 200 watts with a 12 amp contoller
lincpimp 06.10.2008 10:31 PM
No...
Patrick 06.11.2008 05:20 AM
I think car batteries are usually ~40 to 50 Amp hours, maybe a bit more or a bit less depending on the size of the car.
10 nimh cells will give you 12 volts and 3.3 to 5 amp hours capacity depending on which cells you use.
A 10p setup (100 cells) will have similar capacity though. The nimh batteries would be a lot lighter, but probably 5 + times the cost.
Will a 12 amp controller be enough for a 200 watt motor? 12 amps at 12 volts will only be 144 watts.
tc3_racer_001 06.12.2008 10:57 PM
i think he means a small sla... if this is still relevant
in which case 2-4p may be the same?
