-   -   HELP wont move at all (https://www.rc-monster.com/forum/showthread.php?t=1276)
Monkey 09.24.2005 10:24 AM
i jsut had my e-maxx out the motor got hot but i could still touch it and now it wont move at alli can program the controller it beeps and everything but the motor will not turn at all any ideas?
ive swapped radios servos batterys and everything so im assuming something is brok but ive only had i a few weeks sll i did was drive it around a car park for 10min please help
Nick 09.24.2005 10:37 AM
Let the motor cool all the way down.
Check if all the wires are connected properly with good contact.
Make sure all the CVDs and gears can rotate smoothly, nothing trapping. Try taking the motor out and running it just holding it, that will tell you if it is a chassis problem or motor/ESC.
Monkey 09.24.2005 10:44 AM
the motor is stone cold in front of me now out of truck and still nothing shaft moves freely by hand
Monkey 09.24.2005 10:47 AM
update: when i do the program the pinion does jumo slightly when it beeps
RC-Monster Mike 09.24.2005 12:09 PM
What controller/motor is it? can you get through the programming steps all the way?
Monkey 09.24.2005 12:11 PM
its the 9L motor and the 9920 controller and i can get all through the programing
aqwut 09.24.2005 12:28 PM
have you tried checking the normal and reverse switch on ur radio.?.. the normal and reverse for the throttle. i don't know if this would make any difference...
it's pretty hard to fry a motor isn't it?..
I ran 120K on my cheappy himax 380 size motor. and it moved it better than my buddies HV maxx.. :)
Try the switch... mayble it'll help,
Monkey 09.24.2005 12:34 PM
yes i have tried that i have spent the last 3 hours trying to get it to work and all ive achive is getting really pissed off ive had it a few months and barley used it and i was going to race it tommorow for th first time
RC-Monster Mike 09.24.2005 12:36 PM
How many cells? Are you using the controllers BEC? A receiver pack? UBEC?
Did it suddenly stop working, or did it work fine the last time you used it, but wouldn't work the next time you wanted to use it?
MetalMan 09.24.2005 12:42 PM
The motor is probably good, since it beeps. The reason why the motor's pinion jumps when you hear a beep is because the controller sends a pulse to the motor that causes the beeping noise.
Monkey 09.24.2005 12:44 PM
im using 14cells a seperate reciver pack and it suddenly stopped i left it 5min and it started again for a min or so and stopped again and i havent got it to work since
MetalMan 09.24.2005 12:46 PM
If you smell the controller, does it smell strange?
RC-Monster Mike 09.24.2005 12:50 PM
Do you have another motor to try? In another thread, you said the motor was scorching hot. It is possible that it got so hot that it demagnatized itself(I did this with a 10L once). The motor wouldn't move the truck at all. I didn't try to program it after it happened, though.
Also, check to make sure the programming jumper hasn't come loose. This would cause it to not work(would try to program instead of trying to run). Do you get any beeps when you try to run it? Is the reciever lead from the controller plugged into the receiver in the proper orientation(sounds simple, but I have plugged it in backwards myself)?
Monkey 09.24.2005 12:55 PM
i dont have another motor and it was hot enough to touch for a couple of seconds before i had to take my finger away
