MMM Cogging-ideas????
Ok, what am I doing wrong? When I fully accelerate the MMM Neu will cog. I am using Castle link v3.051, a Neu 1515 1y on 4s.
My settings are: MMM Brake/reverse proportional w/ reverse Brake 40% Reverse throttle 40% Punch 0% Drag brake 10% Start power high Motor timing 10 Throttle curve linear |
are you using v1.17?
No 3.051. Will that fix it?
Sounds to me like the batteries aren't keeping up...
I am pretty sure I have the lastest firmware...checking now.
Batteries are TrackPowers 2s1p 4900 mAh Edit: Downloading latest firmware now. I did not have it. thanks!! |
also I HIGHLY suggest you run the ESC at low power start up you dont want the high power start, it advances the timing and your motor will run much hotter and you dont need that much
Firmware did not work it still cogged. I am current balancing/charging the batts and for the first time the "fuel indicator" on the trakpower balancer is completely empty(nothing is lit up)..?
Battery bad?
Duh, never mind. I must have had it turned off. "Orange" on both cells meaning 20-50% charge.
Suggestions - Start power low; timing low; punch 10%
Check all of your solder joints and motor connections... |
Do you think it could be radio interference. It happens more at far distances and so far never near me? I have everything (antenna, rx, esc, motor wires) in the wrong place:
http://pic20.picturetrail.com/VOL143.../318736116.jpg |
It looks like you have the reciever right under the power wires. If so i would bet money thats gonna hurt you. I remember i was racing once and i was getting this CRAZY glitching. I thought for sure someone was on my channel. After taking my t2 into the pits because it was undrivable. I relized the power wires were actualy bouncing on the top of the reciever and actualy touching the crystal. Tucked the wires out of the way and viola, No glitching the rest of the day. Move that reciever!
it is possible...especially after looking at the pic and seeing how close the RX is to the power wires to the ESC,,,I would try to mount the Rx towards the front of the truck |
| All times are GMT -4. The time now is 01:12 AM. |
