Planning on upgrading the electronics in my revo...
At the moment, I am running a MM ESC with Koolflight UBEC, and a Feigao 9xl motor on a TrueRC 4s2p 8K lipo pack. I love this set up (besides for the hot motor) as it has been working perfectly for me for quite a while now. But I would like to go to a little higher quality motor and battery. I pre-ordered a MMM from RCM at teh beginning of May from the second batch, so once that comes in, I can make the order for a new motor/battery.
I have two options, leave the electronics in my Revo as they are, since they are working fine and put the MMM in my CRT.5 which is running 4s. Or I can put the MM ESC with UBEC in the CRT.5 (stock chassis... barely be able to fit it all) and put the MMM in the revo with a Neu 1515/2.5d running off 5s or 6s. That brings me to my next question. Which would be more efficient? Running 5s on the 1515/2.5d and gearing up, or running 6s on it and gearing down? I am leaning towards 6s because it is only 36,630rpm, and if I ever need to show off to the nitro's, I will have the power on hand. :yes: So if you guys can give me your opinions on what you would do if you were in my position, that would be great. Thanks! :yes: |
I am using the stock tranny locked into 2nd gear with the wide ratio gear set. Spur/pinion is 38/18... so basically the exact set up as you are running.
I run the 1.5d geared 22/58 (3905 tranny) on my erevo, with a pair of 4s lipo's at the track all day w/o issues, max speed is 50mph and is PERFECT for racing.. I can show up just about anyone I've come by.. drop in a 5s or 6s and with the same gearing I can easily get to 62mph with a long run way I'm sure I could get 65mph on the 6s. Change up gearing and 70mph is possible. I run the MMM w/ the Neu 1515 1.5d and again it is perfect iMO.
Here is a youtube of just some onroad runs to give you an idea... sorry not track video yet.. but I've run about 10x now approx 1-2hour sessions ea visit w/o problems.. http://www.youtube.com/watch?v=85v85Pn3DMk http://i172.photobucket.com/albums/w...h/IMG_4188.jpghttp://i172.photobucket.com/albums/w...h/IMG_4098.jpg |
That is good to hear that I won't need to change gearing azjc.
stum - how are the temps of the motor after a hard run on the track? |
im glad you got one of the good ones stum(KNOCK ON WOOD BUDDY) lol sorry for the caps
| All times are GMT -4. The time now is 05:22 PM. |
