any one out there have a 8-9xl they dont want
the one in my buggy has seen 220 a few times:gasp: and i added a fan and thermal coumpound, geared 13/48 in an 8ight and after 20 mins i still thermal the motor. upsets me to, i thought i would be ok with the fan on it, nope not really!
http://www.hobbycity.com/hobbycity/s...hless_Inrunner kd36 Front mount holes are 25mm apart. Dimensions: 36×74mm Shaft size: 5mm Weight: 370g Spec. Kv: 1900rpm/V Idle Current: 2.6A Resistance: .0091 Max Amp: 75A Designation: 5408409XL fiegao 9xl RPM/V: 1853 Max Current Limitation: 74A Resistance: 0.0097 IO(A): 2.5 Dimensions (diameter x length): ø35.8 x 74 mm / ø1.4 x 2.9 in. Weight: 378 grams / 13.33 oz |
batt im using a zippy-r 4500 21c-31c, mm esc. punchcontrol 10% motor timing normal, brake 50% motor start medieum
| All times are GMT -4. The time now is 09:19 AM. |
