how is this?
Ok so after lots of thinking and my dad calling me crazy in wanting to spend 400 dollars on a controller. How good is this controller?
http://www.rc-monster.com/proddetail...3sHCS01&cat=21 I want to run it with my feaigo 7xl, Is it possible to run 18 cells on it or is that a no no? How fast could i get with 16 cells and proper gearing? Someone just tell me how this one is please. |
That should be fine for the 7XL, but I wouldn't do 18 cells...
Hey, you live in Chatham, Ontario Toby?.... I'm in Windsor.. |
go with bk!
I gotta get me a BK controller.. I had over 6 different schulze controllers.... I really like the schulze controllers..
I only hated the 18.61K.. They're so weak.. they can't even handle the Basic 4200... The Bk 9918 or 9920 would be cool.. I'm selling my 18.61K this week for $200... gonna try a 9920.... yeah.. the Bk one is nice too.. but that MGM can handle 160 amps continuous.. so you wouldn't have to worry about frying an ESC.... I wouldn't run that MGM on 18 cells.. you'd probably fry it... I bought a cheap $60 ESC for Heli.. I'm gonna see if it will fry with the 7xl.... Hey toby, do you already have the 7xl, or you waitin' to order it...? |
on 16 cells.. taht 7xl is doin't 45000+ rpms....
with 64 spur.. and 22 pinion.. it should do well over 45mph.... |
that's an unloaded kv, put more faith in the BK XL kv ratings.
get the 9920, you are able to use 18 cells with it. |
Ja, get a 9920. You can run 18 cells, and it handles the 7XL just fine. And you can even save a few bucks (and spend it on Mikes heatsink;) )
i do live in chatham ontario!!!!
I have seen pictures (2-4) of burnt up 9920 and i will not be able to afford it. So i was thinkin this one has a higher amp rating. If you guys say that it will be fine and i will not burn it up from jumping and landing with a little throttle then i will take it, another advantage it has over the 9920 is that it is in stock! |
no 18 cells. The 9920's you have seen burned, where have you seen them? And are you sure they were not replaced under guarantee?
i saw one on your site ( i never sayed rather or not they were replaced under guarantee, but wouldn;'t that take like over a month) And random photos
that one on my site is the only one i found.. if you've got more i would like to ge them..
maybe i have not seen, i know i have heard or seen though, i cannot not rember what i had for supper last night. so i can never rember anything
it's probably pretty hard to fry an ESC that takes 99amps continuously....
Maybe get the warrior.. cuz it's capable of 20 cells... |
alright, it seems to be chated up quite a bit, I just hope they are in stock soon, I do live in chatham though, what kind of vehicles do you have?
If i get the 9920 (which i will now) i have two questions, One would be what gearing, two would be 16 or 18 cells, how much would 16 cells cost to get made as well?
| All times are GMT -4. The time now is 11:22 PM. |
