-   -   a123 setup (https://www.rc-monster.com/forum/showthread.php?t=12854)
jlustig83 06.16.2008 09:41 PM
a123 setup
how should i build some 5s a123s to best fit in my old emaxx. thanks
Duster_360 06.16.2008 10:21 PM
Build a dbl shotgun config - 2 parallel tubes of 2 cells each and add a single cell on the top. Put the single cell in the middle on top or maybe a little toward the rear. 5s a123s side-by-side are too wide to run in the older Emaxx - I have that Emaxx and I have built a pair of s-b-s a123 packs. They are way too wide to hold on the batt trays.
The footprint of a dbl shotgun type pac (with extra 5th cell on top) should fit. I have seen 6s a123s built that way - dbl shotgun with two more cells on top - a triangle config fitted to the older E and a G2 (or 3) Revo.
TruckBasher 06.17.2008 12:36 AM
I have a similar setup like what he mentioned but my top (5th) cell is on the middle but will require a bit wiring. foot print should be about 2" x 5.5" or 5cm x 13.3cm. Height should be around 1.8" or so.
Duster_360 06.17.2008 07:28 AM
Remembered this thread where this was discussed - several pics of triangle config. Read #17 for a pre-made dbl shotgun type kit for assembling a123's.
http://www.rc-monster.com/forum/showthread.php?t=12500
jlustig83 06.17.2008 04:37 PM
thank you
