-   Mini truggy (https://www.rc-monster.com/forum/forumdisplay.php?f=43)
-   -   update on crt.5 (https://www.rc-monster.com/forum/showthread.php?t=12863)
super dave 06.17.2008 01:29 AM
update on crt.5
hey guys you are rite this is way to much motor for this truck, hard to get a smooth lap in. i will go with a small kv motor maybe a 4600 or 5700 and still run 2s packs, this is a extended chassis kit new fomat for this kit. please give some help if anyone else runs a motor in this kv range 46-57. this is just something to have some fun with not to be just speed demon thanks guys the top plate i cut from a sheet of carbon fiber and same for the recieve, monster mike is currently out of stock on the chassis kits.
http://i156.photobucket.com/albums/t...Picture017.jpg
DRIFT_BUGGY 06.17.2008 05:47 AM
Don't often see any higher than 4600kv motors used in the CRT.5, the VXL (3500KV) seems to be a popular choice. Tekin also make a brushless motor called Redline which do a good range of KV motors
Arct1k 06.17.2008 06:12 AM
I run one of the faster motors a 7L a few go with the 9L or a 1509 would go in there very nicely
GO-RIDE.com 06.17.2008 09:44 AM
Believe it or not I run a 7.4 volt Novak GTB and 6.5 (6400kv) Velocity motor in my e-crt.5 with truck tires. It runs great geared 12/46 with out any heat issues even in racing. However, I do wish it had a bit more grunt. I'm thinking 11.1 volts with a MM and VXL motor or maybe one of the 50mm Medusa motors.
