MGM 16018 on 6s li-po
I know that this controler can theoricaly handle 6s li-po, but is somebody here run this controller on 6s li-po without any issue.
I run it on 4s for now but i switch to 6s soon, and i'am little scared about that. I don't use the internal BEC and use mechanical brake. So i give a big chance to the controller. Thank you! David |
Mine runs fine on 6s lipo. I do have a koolflight ubec with the internal disabled.
Do you install a 20 ohms resistor on the "+" lead to avoid the spark when you connect the batterie???
no, it's not real bad, actually more prominent on my mm with 3s.
the 16018 handles well on 6s... its stays warm after each 20-30mins bash but never it failed on me...
no issues at all in muggy with Neu 1512 os 6S
| All times are GMT -4. The time now is 03:47 AM. |
