-   -   Hey guys I am back (https://www.rc-monster.com/forum/showthread.php?t=129)
rc4x4nut 02.08.2005 10:49 AM
Hey guys I am back
I am back. After being sick and being on the road I am back. My truck is now completed with GA bulks and diff cups, Maximizer diffs, and CVDs all around. I will have pics up later today.:D
RC-Monster Mike 02.08.2005 10:53 AM
Glad to have you back. I was wondering what happened to you. lookin' forward to the new pictures!
rc4x4nut 02.08.2005 11:09 AM
I had to do some traveling and it kept me off the maxx but I finally got it done. I think I may have to get my rear bulks redrilled. It seems to have a bind with the hinge pin and wont allow for smooth suspension movement.
MaxxFusion 02.08.2005 04:07 PM
Welcome back. Lets see some pics.
rc4x4nut 02.09.2005 10:57 AM
pictures as promised. I put on those crappy 7 cells just to work out some kinks.
http://rap.midco.net/norbert/1b.bmp
http://rap.midco.net/norbert/5s.bmp
http://rap.midco.net/norbert/6s.bmp
http://rap.midco.net/norbert/2bu.bmp
http://rap.midco.net/norbert/3bu.bmp
http://rap.midco.net/norbert/4w.bmp
RC-Monster Mike 02.09.2005 11:27 AM
That is one of the nicest e-maxxes I have seen. Very nicely done. The only thing that stands out to me is the Tamiya connectors on the batteries and speed controller. I highly recommend switching over to Dean's. The stock connectors are innefficient and will wear quickly. You will notice a performance increase when going to the Dean's (assuming you have good batteries). Otherwise, that is ine h*** of a G-maxx!
rc4x4nut 02.09.2005 11:42 AM
Thanks Mike. I will be upgrading the connectors here soon. I havent totally ran the truck yet. It was only used to center the steering and the shifter servos. Also to make sure that i put the diffs on right. The awesome thing about the GA diff cases is that I didnt have to shim a whole lot. I use only 1 teflon shim and its perfect. Now I have to look for a new spur. I read somewhere that the hv maxx are tearing up the stock spurs. Strobe may be coming soon.
RC-Monster Mike 02.09.2005 11:46 AM
The user errors is what tears up the stock spur gears! Tighten the slipper all the way down and set your mesh properly and the spur gears will last a very long time. It is usually a poor mesh or a loose slipper that does the spur gears in.
rc4x4nut 02.09.2005 12:42 PM
Yeah I have it tightened all the way down right now and the mesh is just enough to pass a piece of paper through without tearing it.
HotnCold 02.09.2005 01:01 PM
Sweet looking maxx - def change those connectors to deans - like mike said - there is a big difference in the connectors...I like the way that fan is mounted on the speed controller. AWESOME and NEAT....
