how to find out how many C's a lipos has
hey i have a 1500mah 2 cell lipo and it does not say how many C's it is. all it says is its max charge 1c (1500mah) max disch 7c (10.5 A)
is it a 7C battery? cause thats its max discharge rate. |
Yeah, sounds right since it is only a 1500mah 2 Cell. What brand is it?
wattage. its a old battery but has never been used and it does not even have a connector on it.
but at work we have a 950mah battery that has a 25c and a 1330 that has a 13c why do they have more c then my 1500? |
Does it say that is it the Maximum Continuous Discharge or Maximum Burst Discharge?
Most should say right on the label - all mine give a continuous and a burst rating, some both in C and amps
Lipo performance has improved over time. Cells are getting better and that means more amps output which increases C rating. My integy 1500mah 2S are 15C rated continuous and 20C burst. I have a 2S Flightpower EvoLite V2 1600mah and its 20C rated continuous, 30C burst. Its a better, newer batt than the Intergy. It cost more than the Integy too. Your 1500 is either older when that was the best a cell could do or was made that way to suite some specific end use that just needed that amount of current. |
the "C" rating is the total discharge divided by the capacity of the battery
| All times are GMT -4. The time now is 03:26 PM. |
