-   -   programming mm for medusa 36-60-1600 (https://www.rc-monster.com/forum/showthread.php?t=12954)
big greg 06.20.2008 12:31 PM
i see its a 4 pole motor, right now my settings are 0 punch, normal timing, mid start power, thats pretty much it i think, any body have advice on a better program with the higher pole motor, this is running off 4s in an 8 buggy:yes:
Five-oh-joe 06.20.2008 03:17 PM
You can fool around with the timing some. I found that my 50mm 4800 in my Rustler prefers timing a bit on the higher side (something like 13 or 14 degrees is good so far). How come you have medium start power though?
I also have a more agressive throttle curve, since it lends to how I drive better. That's preference though.
big greg 06.20.2008 04:27 PM
seemed to eliminate the cogging more from a standstill with the fiegao, ill put it down to low and see what happens
