-   -   For the Neu motors w/ a RCM motor mount...will I need more than than the rear cover? (https://www.rc-monster.com/forum/showthread.php?t=12982)
magman 06.21.2008 05:39 PM
Mike sells a front cover for the Neu motors. Is this necessary w/ the RCM motor mount. I know that the rear cover is needed.
DRIFT_BUGGY 06.21.2008 05:47 PM
No, you don't require it, it is to thick for some buggies and isn't enough shaft to be able to put a pinion on. What is it going on?
jayjay283 06.21.2008 05:50 PM
I dunno about all RCM mounts but with the RCM losi 8T mount it made the pinion on the factory flat spot mesh perfect with the nue and pinion and spur and covered up some holes large enough for small pebbles to get into. Didnt need it for my emaxx as its all flat against a solid mount.
http://i278.photobucket.com/albums/k...hedlast012.jpg
http://i278.photobucket.com/albums/k...hedlast010.jpg
magman 06.21.2008 05:56 PM
The Neu will be going into my mbx-5 if that makes a difference. I should probably get it and have it just in case.
