-   -   Questions on CC bec (https://www.rc-monster.com/forum/showthread.php?t=12989)
speed demon 06.21.2008 07:58 PM
Questions on CC bec
I'm running on 6S with one servo and 1 30mm fan and 1 40mm fan. The cc bec is setup at 5.1v and it decided to just stop working and just makes a slight buzzing noise and get hots fast. What could caused this? Is 6S and the fans too much? I plan to buy a new one unless there is a better one out there. If I get another one would going up to 6v help? Would that help so it doesn't have to knock down so much volts?
azjc 06.21.2008 09:33 PM
with 6s you dont have very much headroom, you might want to go with a
Koolflight BEC they have models that can handle up to 45v
http://www.koolflightsystems.com/ultimatebec.htm
speed demon 06.21.2008 10:02 PM
Thanks for the info and the link. I'll get one ordered tonight. I really wanted to drive my truck so I just soldered 4 AA bats in series so I can still play until the bec gets here. Thanks again.
bdebde 06.21.2008 10:23 PM
Also look at dimension engineering ones. I have several and never have any problems.
