-   -   Excel worksheet for some of my speed runs (https://www.rc-monster.com/forum/showthread.php?t=1299)
lipomax 09.27.2005 10:41 PM
Here's an excel worksheet for some of my speed runs.
http://home.comcast.net/~youngsongdmd/speed.xls
You can simply change the KV, and voltage, pinion, spur to get your speeds. The voltages are odd because they're adjusted so the MPH match the actual speeds. Speeds were measured with GPS.
MetalMan 09.27.2005 10:59 PM
If you don't have Excel, there is a program that you can use to figure out speed:
http://www.waits.net/public/rcgears/
It's the one that I use.
aqwut 09.28.2005 08:48 AM
Hey, MetalMan, That RC Gear program is pretty cool...
the excel sheet I use, is pretty accurate to it.... Less than 1% difference... :)
kulangflow 09.29.2005 02:14 PM
I've compared this calculator to my actual GPS tested results and have found something to be quite off by an average of 9.4 mph.
For example, my 8S powered Rusty at 22/84 "should" hit 53.4 mph on 10 cells at 1.05V, but "actually" only hit 40.5 mph ... a big difference of 12.9 mph.
Does this mean that I'm doing something wrong (calculations or actual testing), or that the calculator doesn't include real life items like weight and wind resistance?
aqwut 09.29.2005 02:32 PM
those calcuations are based on a perfect condition... you know... in a vacuum...
now, you have to think about inertia.. wind resistances... voltage drop.... Bearing and Gears Resistance... Tire Tread resistance...
there are some things you must take into consideration... :)
I hope that helps you figure out why...
kulangflow 09.29.2005 02:43 PM
Gotcha .. that's what I was thinking.
So .... for use in real-life testing, do you just assume a certain variable of difference, like 10 mph or something?
aqwut 09.29.2005 02:53 PM
yeah. that's what I do... but I think the the more wattage motor you have.. it'll be a small gap... know what I mean....
but 10MPh is a good number... but with the 8s, you should be well over 40mph...
aqwut 09.29.2005 02:58 PM
swami-rc got his to over 48 mph with 10 cells and 18/90 gearing.. but he was using a rusty....
why don'tyou get the basic 5300, that thing will take you close to 70mph....
kulangflow 09.29.2005 03:08 PM
I'm using a Rusty as well, but with 10 cells and 18/84 I'm only getting 35.3 mph. I wonder what he's doing different with his Rusty to have 13 more mph than me.....
sleepy23 09.29.2005 05:30 PM
holy crap...you got some problems...i run 6 cells on a novak ss5800 in one of my t4s and i get 35 and we all know how weak the novak is
Nick 09.29.2005 05:41 PM
Got to get me one of those 22 series from Santa! :D
lipomax 09.29.2005 05:46 PM
No, these speeds are not best case scenario. That's the whole point of the voltage drop from 1.2 to 1.05 per cell. As a matter of fact, see how my voltage drops from 29.6 volts to UNDER 21 volts when running my emaxx under extreme gearing?
Honestly, I gotta agree with sleepy23 - you got some problem with your batts, gearing, motor, or something.
A 5800 in my B4 went over 43 mph with 6 cells!!!
kulangflow 09.29.2005 06:19 PM
There must be something wrong with something.
I finally broke 51.3mph, but it took 12 cells geared at 27/84! The spreadsheet says that combo should take me to 77mph. Ummmmm ... nope. :)
The controller temp was 105F and motor was 150F. I tried 10 cells and 12 cells with 18, 20, 22, 25, and 27 Tooth pinions on an 84T spur.
I am baffled. This same controller (BK9918) with my 9L took my e-maxx to 45 mph geared at 22/66 on 14 cells, and that's dang close to what lipomax's spreadsheet says. Hmmmmm.... that tells me the controller and cells are fine.
Actually ... I am now thinking the problem is that these calculations are based on 32P gearing, while I'm using 48P gearing. The diameter of a 60T spur at 32P is way bigger than at 48P. How can I update these formulas for 48P gearing? Nope that doesn't make sense. Gear ratio is gear ratio regardless of pitch. Blast!
Thanks for reading my novel ... :-)
MetalMan 09.29.2005 06:56 PM
I have to say that there is definately something wrong with your setup. In my Rustler, I have a Feigao 540 size 12s. When I did speed runs with 4s Lipo, the motor was only pulling about 40,000RPMs MAX at full throttle. I got up to 56.5mph... And that was with 25/87 gearing (or something like that). I am sure I could have gotten it to go faster, but the space I had was VERY limited (as in I have about 100-150ft. for acceleration, and 50ft. for braking).
That said, your motor on 12 cells should be spinning at about 56,000RPMs at full throttle. With high gearing and with enough space to accelerate to full speed, you should be hitting pretty close to 60mph. But if you don't have at least 300ft. for acceleration, you aren't going to do it. For the car, the difference between 50mph and 60mph is HUGE, and so it will take a lot more time to go from 50-60 than from 40-50 (air resistance). Also, if you run with a body, take it off and then run it. The body is actually more likely to slow it down. When I did my speed runs, I never ran with one. Another thing to check is your slipper clutch. For speed runs, you want it tightened down completely. Also, if your tires aren't getting good enough traction, they could be slipping from the enormous power.
Now, if none of this helps, than I am dumbfounded. The only other thing it could be is gears/bearings.
kulangflow 09.29.2005 07:15 PM
Thanks for the reply ....
I've got a great place for my speed-runs. It's a brand new industrial road, smooth and level, very wide, straight, and forever long ... with absolutely zero traffic. :-) I go from as far away as I can see to as far away as I can see (and still be able to control it.)
I've tried with the body on and the body off as well and I made sure to tighten my slipper completely.
I am seriously dumbfounded. I know there's no binding because I can push it quite easily with my finger. My batteries are always 125F when they peak.
I even checked the motor today to make sure it was the 8s.
Any ideas?
