-   -   FLM Bybred and steering interference (https://www.rc-monster.com/forum/showthread.php?t=12992)
highflier 06.21.2008 11:03 PM
OK my struggles to get my truck fixed continue.
Order after order I run into a issue. So here is the deal this time.
Since I blew the rear diff I upgraded to the FLM hybred bulks. Previously I had gotten a Proline Tmaxx steering setup. (replaces the cheap servo saver)
Anyways now as I reassemble I have a issue with the linkage hitting the Combo bulks. Its the crosslink that connects the left to right side of the steering.
I I flip the bar over to the otherside of the arms. Things start hitting the Front skid plate.
Any idea's on how to fix???
Highflier
GorillaMaxx360 06.22.2008 10:50 AM
hmmm i had this problem too, and i can not remember how i fixed it. though once i swiched to the ue servo saver and flm chassis the rubbing stopped.
TDC57 06.22.2008 02:36 PM
I remember something like this as well?, post up a picture or two (that always helps).
Thanks..
highflier 06.22.2008 05:02 PM
gmaxx360 I bet you solved it with the UE
tdc I will do a photo later today. I moved the bar to the other side now it hits the skid plate. I am thinking about just dremeling the skid.
Highflier
highflier 06.22.2008 10:12 PM
Sorry, to lazy to take a pic so far. I desided to dremel the skid plate... then I found out that was a bad thing to do as the wheels would toeout when the suspension flexed. So I went back to the way I tried it the first time, and guess what it did not hit any more. I wondered why, maybe the proline part is not drilled in the center... who cares it fits now. Except the skid plate is weakened. Guess It will work until I order a new one.
suicideneil 06.24.2008 07:08 PM
Sometimes the drag-link bar hits on the ends of the hinge pins, so you need to do a little dremeling on the drag-link so that it clears.
