Sensor wire extension?
Ok, so I have the novak HV system, and an extra half inch or so in the sensor wire length would be great. I would prefer to find an extension cable (instead of splicing and lengthening the wire). Does anyone know where I could find a extender? What about just the male/female connectors?
Thanks for any help |
does anyone know where to purchase the male type connector (the plug on the ESC)?
Or does anyone know if the connector has a specific name? AKA, I want to make (or buy) a short connector for a sensor wire and all I can find are extensions with the female ends. As I cannot unplug my sensor wire from my motor (direct soldered) and I do not want to cut the wires and extend the current sensor (not sure what that would do to the warranty). Anyone got any ideas or suggestions? |
I find that every now and then when I remove the motor or ESC when I am changing something that I notice I am pulling on the wire alittle. I just though it might be nice to give it a little more slack.
after a little googling i found that the male end (b 6b-zr) is available from a company in Minnesota with a minimum quantity of 10.
Hopefulyl I ordered the right thing (we will see when they arrive). |
Thats the only thing that really annoyed me, having a non-removeable sensor wire sticking out of the motor. Every other company with sensored motors has a plug on the esc, and the motor with a seperate cable.... meh...
CMCCLIVE,
What company in Minnesota has the extension? DO you have the website? |
Tuclai,
I appologize if I mispoke, but I did not find a direct extention. What I did find was the male end connector from: http://search.digikey.com/scripts/Dk...me=455-1661-ND It was like $1.90ish for 10 connectors, and $3-4 shipping I think. I then purchased one of the female/female cables GriffinRU mentioned (either Novak or Orion). Cut it in half and soldered the male connector onto it. If this seems to complex PM me as I could probably make one up for you inexpensively. |
| All times are GMT -4. The time now is 03:56 AM. |
