R1pro with a power cap...
Guys,
I've just installed a 30v cap I've got from Mike to the R1 esc. When I first connected the batt to the esc, the cap made a ( fsssssss) sound and I fastly disconnected the batt. I touched the cap and it felt very hot. I reconnected the batt again and again the cap went berserk. Do you think this is a reverse polarity issue? Shall I solder it the other way around? Thanks, Al :) |
sounds like reverse polarity...u probably need a new cap, the side with the stripe is the negative side
I thought the side with the stripe is the POSOTIVE pole......
Thanks a bunch, dude! |
no problem!
i hope ur cap isnt dead |
| All times are GMT -4. The time now is 10:44 AM. |
