-   -   Basher Truggy Oils? (https://www.rc-monster.com/forum/showthread.php?t=13051)
BL_RV0 06.23.2008 11:03 PM
Basher Truggy Oils?
What diff oil weights should I use for my Hyper ST with mashers with a 1515 on 5s for bashin and jumps? What's a good starting point?
lincpimp 06.23.2008 11:18 PM
I usually try out what is included with the kit and go from there. Generally softer springs and thicker oil will provide a plush ride, but will have body roll. Thinner oil and heavier springs will be more bouncy off jumps, but should hadle smooth areas at high speed well.
BL_RV0 06.23.2008 11:36 PM
In this video, at 13 seconds, does that package contain shock oil?
http://www.youtube.com/watch?v=y8zt1qOfqpM
lincpimp 06.23.2008 11:37 PM
I am sure that the kit contains shock oil.
BL_RV0 06.23.2008 11:38 PM
Main question is, does it contain diff fluid?
Mister-T 06.24.2008 08:10 AM
Most of the time you have basic 300 or 400 cps oils provided for shocks, and grease for diff. But heavy silicon oil for diff isn't provided. Best choice would be to pick 3 most common grade
3000
5000
and 7000
Most of the time thickest oil add motricity but you lose reactivity in corners.
