-   -   ESC temp ? (https://www.rc-monster.com/forum/showthread.php?t=13098)
KaztheMinotaur 06.25.2008 05:34 PM
ESC temp ?
I assume that ESC temp should always be measured on the heat sink? My Hydra 120 is a lot warmer on the electronics....around 150.
suicideneil 06.25.2008 06:51 PM
Depends on the esc layout- some have the heatsink directly on & above the FETs (a la MM), where as that hydra has the fins that stick out between each layer of FET boards I think? You'll get higher temps on the electronics, as the fins will drop i temp the further away from the the boards they get due to cooling down...
KaztheMinotaur 06.25.2008 07:23 PM
I'd like to figure out a way to mount the fan facing the electronics instead of the heatsink. It is running fine though.
jhautz 06.25.2008 08:52 PM
I always check around for the hottest spot I can find on the esc and thats the temp I go by.
KaztheMinotaur 06.25.2008 09:31 PM
Yeah.
