What Neu Motor for CRT?
Hi Guys.
I might convert my Jammin' CRT to Brushless and screw Nitro for good! 1. What Neu motor is the best combo of Speed/Torque? 2. What Gearing is the best for staying cool and a good Speed/Torque Combo? Thanks Guys. |
I'm a fan of the 1515 2.5D/F 5/6s on appropriate gearing - use brian's calc
Ok, Thanks.
What the Differential Ratio? |
Divide the diff ring-gear tooth count by the diff pinion gear tooth count.
And once you find out the tooth counts, let me know and I'll add it to the calc (note: I need the tooth counts, not the resulting ratio). |
I can't find the Ring Gear and Diff Pinion anywhere.
I run a Neu 1515/1Y/F on 4S geared at 13:62.
I also run a Neu 1515 1/y/f on 4s geared 14:62, I would guess it hits 35-37mph.(this is in a crt)
Bye:mdr: |
2. Would the 1515/2.5d be faster? |
Not Fabio..........lol
You've got to run lipos buddy. Neu 1515/1Y/F on 4S is the fastest, cheapest route probably... |
What do you guys say? 1515/1Y on 4s? or 1515/2.5D on 6s? |
Is a 2.5D on 6s faster? |
| All times are GMT -4. The time now is 04:34 PM. |
