Two digital servos and a CC BEC have gone into thin air.....
Yep, indeed.
After I've installed and combined a CC BEC, a Futaba Digital S9951 servo, a FASST receiver, a Tekin R1PRO, a NEU 1512/1.5D and a 1000MFD 35V capacitor together, the servo( and another one I've tried as an experiment) and the CC BEC were fried up abruptly. I don't really know what've caused this. Although I've ordered the things again, I'm afraid the same issue might occur. I've got to identify the problem and solve it befor it happens another time. Please, guys, help me..... Thanks, Alawi El-Jifri :) |
You did disable the R1Pro BEC, right?
Yeah, I did.
Guys, for real I did not open this thread to have a ten page chit chat( though I'd like to).
All I'm asking for is some help from the pros( Where in God's name are they??!!!). |
its hard to tell without a wiring diagrahm but I am guessing it is related to the BEC and the cap either or both were wired incorrectly...can you post a diagrahm ? when you programmed the BEC was it working ok? |
I've read in another forum, that some of the digital servos can pull more then 5A at stall. The guy that mentioned went to say 10A, but I don't think the normal sized servos are there yet (I might be wrong as we have servos that can put out over 500oz/in http://www.servocity.com/html/hsr-59...ra_torque.html). In electronics though as I've learned from our great members here, the actual peak might be even more. You could also have a unit that was faulty. This things can and will happen to anybody. I've read report of BEC units failing.
I've also heard that when the CC BEC fails, it sends full battery voltage to the load instead of simply not working like most others do.,
thats not good.....maybe I will invest in a koolflight ......
Oh no.....
I've just ordered another CC BEC ( the one in the CRT.5 is working perfectly) and a low profile digital servo. I think I'll need to use higher grade capacitor. Maybe a 2200mdf 25v ones. Did anyone use such a capacitor with their R1Pro? BTW, how can I program the BEC? |
do you have a volt meter? check the bec output
That's why I still use Rx packs. It's been rock solid.
Yeah. I've never had any problems with rx packs.
I smelled it.....mmmmm...full of bar bq. |
I use a CC BEC in my buggy with no issues so far, but plan to make a circuit to cut off power to it if the output goes too high. The KoolFlight or DimensionEngineering or Hercules BECs are great alternatives IMO; low/no noise, strong output, and good efficiency. Receiver packs obviously work well, but it's just one more thing to charge.
| All times are GMT -4. The time now is 06:13 PM. |
