LVC on MMM
can i run my lipos until the lvc on the MMM kicks in?do you guys do that?im worried because they say you cant run lipos lower than 3v/cell and what if the discharge rates on each cell are not equal.im tired of worrying about over discharge,keeping track of running time,etc while running.id really prefer to run til the LVC kicks in.in addition,ive never really taken my batts to the limit.maximum charge i put back is 3600mah so i still dont know what my max runtime is
I have my LVC set @ 3.3 vpc and my Revo will slow down before the LVC will kick in
For best life of lipo's, you should only run about 80% out of the pack. I run LVC at 3.25/cell, but I see a drop in power before it kicks in. I rarely run them down that far though (or try not to).
it gets so frustrating when you end your run just to be safe then find out you still have a lot of juice left on your lipos
How does the mah come into it with LVC? I have 5S 5000mah and have my LVC set at 3.4V per cell. After 35 minutes my battery started to go a little slow so I stopped it and it still had around 17.6v left and when I charged the battery it charged 4780mah so it nearly was at 5000mah, so wouldn't I run out of mah before voltage is to low?
why not just use the auto-lipo setting?
| All times are GMT -4. The time now is 07:02 AM. |
