Evader
My friend wants a cheap but nice BL setup for his evader, he also wants to know some good but cheap hop ups
i would recommend getting something else to put brushless in because im not sure if the tranny would hold up.
he already has the Evader though
true, but i dont think it will even hold up to brushless so i dont think it would be wise. im not positive though.
It should, its a Losi XXT in disguise.
I just did this.
All the Aluminum parts I could buy for the Evader. feigao 8s, mgm120(overkill) fun on 2s lipo, insane on 3s lipo Killed 2 diff gears, one spur gear till I tighted everything tighter than I thought it should be. ~35mph on 2s lipo and should last a while. ~50mph on 3s but can't keep it on the ground. Working on a front spoiler. Had to remove rear wing, drag pulls the front off the ground. |
i killed 2 diffs gears and fried a slipper plate on my frie'ds evader with a Novak 5800 before he took it back from me.
so it is possible but definatley going to cost him at least 500 toget it going good
With the motor and controller, anything cost $500
Just put $300 into a RC18T Expect to put ~1000 into E-Maxx Speed cost money, how fast do you want to go? Yes, 0-50 2.0 sec Evader 0-50 3.2 sec Z06 Power to weight ratios do matter!:cool: |
Somewhere I saw a metal diff gear and idler gear for the XXT. It will fit the evader. Let me see if I san find it.....
BL_Force- how do you like your miniquake se with the brushless?
i have a brushless evader or had one until by bro drove it in the creek. it was very squirly and hard to control and did about 40 with a novak gtp and velocity 5.5 never had a drive train problem but i added aluminum idler carbide diff and trust balls, associated diff and rings and a rear tow block brace. now that my novak fried i just ordered a mamba max esc and im gonna put a Feigao 380C Sensorless Brushless Motor. and ill run a 6cell
IB4200 pack until i can afford a 3s lipo |
3 Attachment(s)
here are some pics of my evader
| All times are GMT -4. The time now is 09:08 AM. |
