-   -   Mechanical Brakes and gearing limits on an MBX5 (https://www.rc-monster.com/forum/showthread.php?t=13230)
Mightytaco 07.01.2008 08:56 PM
Does anyone know the smallest pinion you can run using mikes plate and a 46 and or 48 tooth spur on an mbx5?
Geared 16/46 running a Neu 1512 2d/f and mgm 16018, the esc got a little hotter than i wanted it to. Motor braking didn't help either. I'm going to try adding the mechanical brakes and gearing down and want to get the smallest one i can get!
starscream 07.01.2008 11:04 PM
Mike has a front motor cover that will help with gearing options with mech brakes
Select the .25" brake spacer from the drop down when ordering
http://www.rc-monster.com/proddetail...rontmotorcover
