crt.5 update
hey guys here is an update on my crt.5, i have taken the advise from the forum and put a smaller motor in the truck, cc esc and 4600 motor combo kit. this has proven to be just what i wanted, tested on tuesday and all is good, this has made it much easier to drive and smoother power delivery, great over the jumps and fast out of the corners. i ran with a 13 pinion and 2s 4400mah lipos, diffs (7 10 3) around 15 minute run time this has put it right near the top of the fun list.
http://i156.photobucket.com/albums/t...ui/Picture.jpg |
Looks good!
Great news, glad to hear your enjoying it
what kind of temp are you running with this setup?
Yeah, what are your temps? I wasn't happy with the temps with my 4600 combo on 2s, and that was geared 46/12.
i am about to try a mamba max 5700 with a 12t... i hope it will work!
Same here, if I can ever get the blooming thing to calibrate with my 3PK!!
Not sure what pinion mine came with, but I'm starting out with 2S and will see how it goes. I scored a like new one on Ebay that included an elect conversion as well. I will be using the RCM kit and the pinion from the other. I expect to buy a 3S as soon as I get all the kinks and bugs worked out. |
I just got mine together yesterday, not my final motor though. I started with a used roller w/ rcm motor mount that I picked up from a member on here. I wound up purchasing an ofna extended chassis conversion on ebay and switched everything over. I made a battery tray out of plexi to start with but have since made one from alum to install this weekend. I put my mm in and the only motor I have available to me until my package from mike arrives is a Novak HV4.5. I have a spektrum 3100 rx bound to my DX3R radio and a spektrum z590 servo. I am extremely pleased with this truck! I originally started this truck to replace my rc18t with something a little bigger but that has the ability to corner without rolling like the little truggy. Now I think I will be selling my vxl rustler as well now! This should be on everyone's list of trucks!
all my temps are good esc, motor and lipos all under 60C 46-13 gearing, 4600cc combo on 2s lipos just tried a change to a 14 spur and drove a little smoother and a little more stop speed just a little increase in temps no effects on run time all is still good. i only run at the track no bashing.
Looks Good... Nice truggy...
i will get this in a few days and i was wondering wether this was a good choice. |
| All times are GMT -4. The time now is 04:21 PM. |
