-   Mini truggy (https://www.rc-monster.com/forum/forumdisplay.php?f=43)
-   -   CRT .5 tires being ripped apart (https://www.rc-monster.com/forum/showthread.php?t=13282)
Hickoryhead 07.03.2008 10:17 PM
I have an issue with my right front tire on my CRT .5. I am running stock pro-line bow ties with a MM and a Lehner 1920/7. The battery is a Maxamp 8000 mAh 3 cell Lipo. After everything was put together on the first run I noticed that the Right front tire was ballooning drastically. I thought for some reason I had glued it wrong. So I rotated the tires to see. They all balloon when placed on the right front. Any thoughts of why the right front is getting more power or torque than the other 3 tire positions?:neutral:
brushlessboy16 07.03.2008 10:20 PM
seems like something on your front left drivetrain is dragging, check bearings
Hickoryhead 07.03.2008 10:41 PM
I checked that. Left side seems fine. Nothing that I could tell.
IBJAMMIN 07.05.2008 03:47 PM
3s 8000mah pack in a CRT.5? you have to much right side weight the right front tire is getting more traction then the left front tire you need to run a thicker oil in your front diff to keep it from diffing out. :)
