death motor!!!!or not??
i run today my e-maxx and after 10min of hard acceleration and braking in the street,,,the truck look like loose brake...or something else..and the motor start to cogging...i check with my gun temp and the motor was 290F:gasp:(feigao 6xl)my esc (mmm)90f and the pack(lipo maxamp 8000hv 7,4x2) 101f......no power come out of the motor and no brake.....it is burn????i try another motor and no issue at all and the esc run flawlessly....i was scared i was tinking that my mmm was died:yes:
maybe you demagnetized the rotor from excess heat
open motor an check rotor for magnetism |
yes i did this....and :yes:the rotor is very lightly magnetized,,,, its complytely out of buisness:lol:
that just gives you a reason to get a better motor :D
i waithing for my neu 1515 1,5d f:mdr:i have a 1515 1y but not enought kv for my 4 cell set-up:yes:
You can't expect much more from a 6xl though... those things will run hot as hell... :lol: Why isn't the 1515/1y enough Kv for you? You can easily reach 45mph on 4s with it...
http://www.youtube.com/watch?v=-NHFZsd1MqM Bye:mdr: |
im geared 20/68 and ive got a run time of 15min max at 34mph(calculed with r/c calculation)with a pair of 5000mah 25c neuenergy...if i go up like 22/68 i could get more speed but the courant draw is more significant....no???
If you gear a 1515 1y on 4s for the same speed as a 6xl on 4s, then the neu should have a bit more runtime and less heat.
right....my top speed is lower with my 1515 1y vs the 6xl but wowo:surprised:the max temp that i reach is 114f(compared to my death feigao 6xl 290f) for 20 min of street bashing....
your right....i never think about plug one 11,1 volt with a 7,4......i never think that it was possible:yes:you give me a good solution!!!:rules:
this is what i tinking:yes:but now i have a 1515 1,5d to come...can i run this motor on 5cell ??? or keep 4 cell...i would 45mph im geared 20/68...
| All times are GMT -4. The time now is 01:44 PM. |
