Is UE still in operation??
I just got a few UE stuff from ebay and I need a few replacement parts like shocks rebuild kit and shafts, spyder 6 diff case. Seems like everything I want are OUT OF STOCK:no:. Any idea guys? where else can I get parts like those?:neutral:
They're still in operation albeit very limited.
Unfortunately
Well unfortunately Robin (owner) does not seem to care too much about the R/C side of his operation these days. It is too bad for us, but the only way to get parts now is to either catch people selling them on ebay or here, or sending Sam or Robin an email requesting parts. Sometimes Sam is good about finding stuff laying around the shop that he can ship to you. UE gear is the best, but also the hardest to find. RCM has similar stuff available from FLM.
The shock components found in the UE super shocks as well as the six spyder gears are all made by Ofna( except for a few secondary stuff). Go look for them at towerhobbies and other places that sell Ofna products. You'll always find substitutions. :yes:
Motherload parts
Here's a list of parts on the Shock motherload:
OFN 40057 Threaded Ring 4 UE 10122 57.75mm TiN Shafts 4 OFN 40059 Threaded Ring's O-Ring 4 UE 81036 Ø6mm Standoff 4 OFN 40063 Spring Holder (plastic) 4 UE 10125a Spring, White (lightest) 2 OFN 400058 Dust Boots 4 UE 10125b Spring, Red 2 OFN Aluminum Shock Cap's O-Ring 4 UE 10125c Spring, Blue 2 OFN Aluminum Shock Caps 4 UE 10125d Spring, Black (heaviest) 2 OFN Rod End Balls 4 OFN 32033 Bladders 4 M2.5 Nyloc Nut 4 OFN 32235 Piston 4 M2.6x5 Flat Washer 8 OFN 32237 3.5mm O-Rings 8 M3x30 Socket Head Cap Screw 4 OFN 32237 2mm Thick White Spacer 4 M3x45 Socket Head Cap Screw 4 OFN 32237 1mm Thin White Spacer 4 M3 flat washer 8 OFN 32237 7mm Snap-Ring 4 M3 Nyloc Nut 4 OFN 40056 Rod Ends (plastic) 4 OFN 40057 Threaded Ring 4 |
Yeah, most parts are made by Ofna.
Thanks for elaboration, George! |
George, great listing, thanks for the detail.
In trying to buy boots, the number you list has one too many zeros, boots are OFN 40058. |
Thanks for pointing t out. WHat I also found out is the Kyosho shock boots are stronger than the Ofna. They're thicker than the Ofna's. It's part number IFW 154. You can just cut 3.4mm off of it but I didn't have any problems with the stock length.
http://i256.photobucket.com/albums/h...Picture427.jpg |
| All times are GMT -4. The time now is 05:18 AM. |
