-   -   keep my 7xl or get 9xl for my emaxx (https://www.rc-monster.com/forum/showthread.php?t=13324)
petewalford17 07.05.2008 08:20 AM
should i sell my 7xl and get a 9xl or are there any good motors not neu too pricy
e-mike 07.05.2008 08:30 AM
9xl will run more cooler....:mdr:
petewalford17 07.05.2008 08:31 AM
will a 22t pinyon be ok and spur be ok
e-mike 07.05.2008 08:34 AM
what is your spur...but a good settup i think for my experience is 22/68 with a 9xl:whip:on 4cell lipo
petewalford17 07.05.2008 08:35 AM
22/64
e-mike 07.05.2008 08:46 AM
try 22/66 for less heat:whip:
petewalford17 07.05.2008 08:47 AM
where can i get Feigao 9xl for best price
azjc 07.05.2008 09:51 AM
expect to pay about $80 for a 9XL and $125 for a Medusa 60/2000...the Medusa being a better design its a pretty good mid priced motor between a Feigao and a Neu
Arct1k 07.05.2008 10:09 AM
http://www.rc-monster.com/brushlessmotors.php?pg=3
Mike has the medusa's at $115 and the feigao at $70
coolrunnings 07.05.2008 10:20 AM
I Think the wanderer/feigao 9xl motors are longer and have more power right? I believe the shorter medusa is the equivalent of like an L. I know that a feigao 9xl does work perfect on 4s but you will want mikes heat sink motor clamp no matter which one you get.
azjc 07.05.2008 10:27 AM
Originally Posted by coolrunnings (Post 188490)
I Think the wanderer/feigao 9xl motors are longer and have more power right? believe the shorter medusa is the equivalent of like an L. I know that a feigao 9xl does work perfect on 4s but you will want mikes heat sink motor clamp no matter which one you get.
you right on the legth difference the XL can is 74mm and the Medusa is 60mm, but the deisgn the Medusa is better, also you could wait when Medusa releases the 70mm can which has been said to be August
asheck 07.05.2008 11:02 AM
I run the Medusa 2000 in my Erevo and it's much better then the 8xl in my maxx.It's got more power and runs cooler on higher gearing.By the time you add the heat sink there's not much difference in price.
petewalford17 07.05.2008 01:13 PM
ive got rc monster clamp and 7xl is the 9xl ok or the madusa beter then the 7xl so should i keep my motor or change it i would keep it if i could get the gearing right but if i got a lower kv motor would i get the performance still.
asheck 07.05.2008 01:21 PM
I can only tell you from my experience with the 8.But going from that I would think it would still outperform the 7.I would consider it a big downgrade to go to a 9xl.
petewalford17 07.05.2008 01:23 PM
so should i go with the 8xl or keep my 7xl
thank you
