-   -   Wired Backwards? (https://www.rc-monster.com/forum/showthread.php?t=13338)
JOEX 07.06.2008 12:02 AM
Wired Backwards?
1 Attachment(s)
I made a boo boo...:whistle:
Added some connectors to the a123 batteries I got from kulangflow so I can use the series adapter I made awhile ago but I put them on backwards:oops:
Will this still work?
azjc 07.06.2008 12:08 AM
you need to wire them correctly or your batteries will be no more
VintageMA 07.06.2008 12:10 AM
I would say redo the connectors or re-wire the y adapter.
If you hook it up the way it currently is, you will be connecting + to - and - to + and you'll probably let your smoke out in a bad way.
JOEX 07.06.2008 12:13 AM
That's what I thought... I need more soldering practice anyway:wink:
Thanks
Sammus 07.06.2008 12:15 AM
FWIW when my sidewinder esc first came a little while ago I accidently soldered my deans on backwards, I hooked it up, no go. I freaked out, unplugged, resoldered backwards again (This was not one of my better days :lol:) repeat, then got it the right way. the esc and batts were fine :neutral:
azjc 07.06.2008 12:23 AM
speaking of brain farts
I was in the process of disabling the on board BEC on my Mamba 25 for my RC18 and use an extra CC BEC I had... I programmed the BEC and wired everything up than when it came to pulling the red wire you can guess which red wire I pulled...:diablo:..than everyone was out of the BECs but the truck needs the diffs rebuilt anyways...so it continues to sit
JOEX 07.06.2008 12:36 AM
1 Attachment(s)
I'm a little slow...:sleep:.... Just pulled the terminals out and switched them around, no resoldering.
This look better?:whistle:
Sammus 07.06.2008 12:48 AM
pulled the terminals out? is that some fancy thing you can do with traxxas connectors?
lincpimp 07.06.2008 02:40 AM
Yep, they will fit on either side. You cannot use the male terminal in a female plug casing though, as they are different.
