-   -   MM braking weirdness.. on my Hyper ST truggy (https://www.rc-monster.com/forum/showthread.php?t=13346)
Finnster 07.06.2008 12:55 PM
Finally got my Hyper ST finished and have been driving it around testing it. All looks good except I'm having trouble getting the elec brakes to work how I like.
Basically there is very light braking action, then all of a sudden very hard brakes nearly locking the front wheels.
Setup is this:
Hyper ST truggy
4S/8XL/MM
7/10/3 diffs
Futaba fasst radio
brake curve linear
brk str 20% on MM
brk str on radio: 16%
Epas @ 100%
Brk Exponential on radio set from 0% then last time 40%.. no effect really.
Now, the weird part is if I go down one more notch on the radio brk str, to 14%, the brakes are basically gone. I'm not really sure how to dial more brakes in on partial brk w/o causing severe braking at the high end. I fiddled drawing curves in castle link, but just left it to linear as I wasn't getting it right. Plus I can easily dial exp on the radio.
I've had this MM on my CRT.5 I didn't have such an issue. Any ideas?
I'm really missing the feel of the manual brakes on my Revo. :(
brushlessboy16 07.06.2008 01:19 PM
adjust the braking curve on the MM so that where the brakes get hard flatten out the curve
Finnster 07.07.2008 10:55 PM
No effect. No brakes until full trigger, then just hard brakes. WTF
brushlessboy16 07.07.2008 11:14 PM
hmmm
try flashing the code on to the mm?
Arct1k 07.08.2008 07:12 AM
DX3? Have you set that channel to exp? I would reset your TX and MM to defaults and reset your end points on the MM.
