-   -   Brushless Hyper st pro Build (https://www.rc-monster.com/forum/showthread.php?t=13390)
Pedebeater 07.08.2008 02:48 AM
I am finally planning my truggy project. After a long time of debating I think i found everything i was looking for. I wanted the truggy itself to be top quality without killing my wallet, so me and a buddy found the Ofna Hyper st Pro kit, $450 new, not bad. Of course I will be using to rcm motor mount, if it works with this model. Once it is rereleased i will be using the monster max for this build. I found the kb45 8L motor to be quite appealing, it's a beast! I have heard great things about it, and it should be more than enough power to push along my truggy. And as long as I am ordering the motor from unitedhobbies I may as well order the other things i need, like a bettery and servo. I have heard good things about the Zippy-H 4000mah 25-35c 5s battery, so why not give it a try. And I found a decent looking servo for dirt cheap, I have no idea what to expect. All links are below:
Truggy:
http://www.rcplanet.com/Ofna_Hyper_T...p/ofn14332.htm
esc:
http://www3.towerhobbies.com/cgi-bin...&I=LXUWH2&P=ML
Motor:
https://www.hobbycity.com/hobbycity/...dProduct=4938#
Battery:
https://www.hobbycity.com/hobbycity/...5C_Lipoly_Pack
Servo:
https://www.hobbycity.com/hobbycity/...idProduct=3880
All comments and suggestions are greatly appreciated. Thank you.
brushlessboy16 07.08.2008 06:56 AM
have fun looks like a great conversion, wat pinion are oyu gonna run
Takedown 07.08.2008 09:20 AM
Yes, it'll be a great conversion indeed! Now we can actually have some fun bashing at the Cub Foods BXM track and maybe at winnebagoland.:yes: We should ride on up to Green Bay and run on their huge indoor track aswell. "Biggest in the state"
BTW: Kershaw sells 6mm bored pinions.
Arct1k 07.08.2008 09:32 AM
The KB has I believe 30mm motor mount spacing which means it won't work with mikes mount.
It also uses a 6mm shaft so you will have difficulty with pinions - You may be able to get ones that have been drilled out but I doubt they will be hard enough to last against a steel spur.
That servo is good speed wise but light on torque - HS5595 are going for $80 why skimp after spending so much on a kit.
PS Worth checking EBAY I picked up my ST Pro for 406 shipped
mxracer 07.08.2008 11:24 AM
worth pulling the shaft/rotor out and getting it machined down to 5mm ?? will save alot of headaches with pinions gears .
im watching this thread closely as i have the same truggy and motor plans in the woodwork
Takedown 07.08.2008 11:32 AM
Hey Act1k, Wouldnt 130oz/in be plenty for just bashing and messing around? I dont think he's going to get into any racing.
Finnster 07.08.2008 11:39 AM
I have my doubts about that motor. As above with the size concerns, it sounds like the motor tends to run hot. You usually get what you pay for, and in this case I don't understand cheaping out on the motor when there are some that would work better for not much more $. Sometimes you can spend a dollar to save a dime.
I would look at getting a 9 or 10XL, or better yet a medusa 60mm motor, either a 1600 or 2000kv.
The hyper mount works great, however the ST spur is quite a bit wider than the buggy 46T that the mount's spur guard is made for. PLan for this else order a smaller spur (i got a 46T, but it puts a smooth can XL right upto the rear brace. Not sure bigger motors would fit.
G/L
The 5955 TG is an awesome servo too. I had it in my Revo and now hyper ST. Tons and tons of TQ
Finnster 07.08.2008 11:42 AM
I would file that under spending a dollar ($1) to save a dime ($0.10)....
Arct1k 07.08.2008 11:48 AM
The ST is known for its buggy handling and excellent turning - If you're spending 400+ on a kit and buying a mmm I don't understand not balancing the purchase with the motor and servo.
If the intention is that these are a stop gap then no issue but experience has shown it tends to be false economy.
My 2c is that I personally think you'd be better off saving $150-200 by buying a nice roller and then buying a better elecs (motor and servo).
PS 132 is at 6v - the mmm is set at 5.5v so your looking more like 125.
Pedebeater 07.08.2008 01:40 PM
Well seeing how the kb45 has the wrong mounting demensions I am going to skip it. But seeing how I am making an order from unitedhobbies I may as well buy a motor that will atleast get me started untill I purchase a motor of higher quality. It seems that unitedhobbies replaced there feigaos with the new KD36 series, and customers have been having better luck. So I may as well give one a try.
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
Please let me know what you think.
Takedown 07.08.2008 11:19 PM
The KD 9xl should be a perfect motor for the time being...
Pedebeater 07.08.2008 11:38 PM
Thanks Takedown. I hope that motor surprises me. I am really looking forward to this project. It will be my first kit!
BL_RV0 07.08.2008 11:57 PM
Cool. In the last few weeks there have been 5 Hyper ST conversions. Did I start a trend? (Mine, Yours, Finnster's, Arct1k's, and lincpimp's.
Pedebeater 07.09.2008 12:21 AM
I have wanted to do a truggy conversion for the longest time. And now that I see how cheap the pro kit is, it's a no brainer. But yes, I am looking at all of these great builds for help, thank you.
BL_RV0 07.09.2008 12:30 AM
Do you like mine? Which is your favorite?
