New One-Piece Battery Tray Question
Is there enough material to dremel out a 4-6mm groove out of one side so the tray will lay flat and to the edge of a crt chassis. I want to make sure my battery has no way of contacting the spur gear.
It looks like the wall thickness is ~1/8" thick, don't know if that is enough. If you need room, how about mounting it on its side?
For the CRT, you could use the standard tray without a spacer. There is plenty of room on the CRT to mount the battery and clear the spur gear. Our motor mount also has a built in "guard" that is meant to prevent the battery from contacting the spur gear. :)
| All times are GMT -4. The time now is 02:31 AM. |
