CRT.5 Extended Chassies/RC Monster
what bodies are you guys using on your CRT.5 Extended Chassies and RC Monster chassis? What fits the best?
Some run 1/10 bodies but you can still use the standard CRT.5 body. The still use the standard CRT.5 body on the new Extended Version of the CRT.5 but the front mount is switched on the other side of the shock tower (or something on the line of that)
I've get a good fit from the Losi RTR XXX-T body. It is a lot narrower than most 1/10 truck bodies. It fits great by just cutting off the back wing section of the body.
| All times are GMT -4. The time now is 02:48 PM. |
