Next day E-Revo, is it geared right?
I love it when Tower ships from Arizona. I always get it next day and with the $35 coupon and $30 credit I had, I couldn't pass this up. Anyways I gutted my LST2 and put the MM/Neu 1Y/F in this badboy. All I have is a 18T pinion at the moment. Will this do? Or should I gear lower?
I tried using the speed calculator but I don't think I'm doing it right. My TrueRC 6400 lipos fit just right. I should be able to run it tomorrow a little. Also anyone know of a site that has MMM in stock? http://i160.photobucket.com/albums/t...o/CIMG3384.jpg http://i160.photobucket.com/albums/t...o/CIMG3386.jpg http://i160.photobucket.com/albums/t...o/CIMG3388.jpg |
Picked up two of these yesterday at Toy's R Us to try out also. Looks to be a nice launching platform.
http://i160.photobucket.com/albums/t...-4545789dt.jpg |
Setup looks really good!
Were you able to get 18/68 to mesh properly without doing anything? Or do you have the fins ground down? Trying to see how low I can gear down with my Neu Finned setup before it bottoms out. -Cory |
Nice setup, I almost had the same setup but Im not using neu motor :whistle:
For the gearing, I think you might need up the pinion size a bit, calculator show about 2700kv+++ but I might be wrong also :intello: By the way did you made the mount for the ESC or did you buy it somewhere else...I made a plastic mount but doesnt look sturdy... |
Looks great, bet you can't wait to try it out. I doubt anywhere has the MMM in stock.
Thanks for the comments. The 18/68 meshes just fine. The fins don't get in the way at all. The only thing I don't like is the Neu hits the body. If I land on the lid I'm hitting the motor full on.:neutral: The best I could for now was to raise the body. |
http://i160.photobucket.com/albums/t...2/CIMG0605.jpg |
Tower Hobbies 11190 Trademark Dr., Ste 101 Reno, NV 89521 Still NV, that's pretty good for next day. |
Interesting - first time I've seen someone use the front motor mount in the e-revo. It is a bit of a rear-weight biased truck so that may even things out a bit - although it raises the CG up about and inch or two from the rear motor mount.
Let us know how it runs - I may have to try that config out. |
I'm dying to try it out but I'm stuck house sitting today. I did clean my LST2 because it lists tonight on Ebay. I hope it sells, I gotta pay for my next project.
http://i160.photobucket.com/albums/t...k/CIMG0620.jpg |
i just picked up the two 4s's from you man those went cheap
Yeah I know, but at least it went to a fellow member here.:smile: I know they'll be put to good use.
your revo looks nice btw,i really wanted that 8000, my computer messed up or something, it wouldve went in my truggy, well i got your others, now i have like 5 lipos for the 8ight! lol.
| All times are GMT -4. The time now is 07:36 AM. |
