Medusa Motors End Bell Question
Do the medusa motors need any mods to keep end bell from poping off etc or is this not a problem with them....I thought I read somewhere someone using few drops of CA to hold motor end bell together as a precaution...
I thought the medusa's were rebuildable.:neutral: If that is correct then ther endbell will be held on with screws, and you will have no problems with that.
Please correct me if I am wrong |
The back endbell kept popping off on mine, so I just used some CA glue around the edges of the cap and so far it's been doing just fine.
The front has no endbell- it's a part of the can/is the can. |
So are the endbells of medusa motors pressed like all of the chinese motors? I was planning on getting a 36-60 2000kv motor, should I rethink my choices?
Why not just use the RC Monster heatsink clamp. It would work the same for these motors as it does for the Feigao's
I was thinking that also. It actually looks like Mike is making one for the medusa's. Because there is a "L" size heatsink anodized blue.
I will most likely buy the motor for my upcoming hyper st pro and run it with the rcm blue heatsink/clamp.
| All times are GMT -4. The time now is 09:27 AM. |
