HV 7.5 Motor, Good On 5-6s?
I was wondering if the HV-Maxx 7.5 motor with 5mm shaft would be a decent motor to do a conversion in a 8th scale buggy on 5-6s lipo with the MMM set properly. I know the kv is a little high but would it outpreform the 6XL feigao motor on the same voltage seing their around the same kv? I wanted to know because novaks motors are 4-pole sensored and you'd think they would preform great in a 8th scale in sensorles mode tuned properly on 5-6s lipo. All help would be greatly appreciated.:yes:
Its a 3000kv motor.... on 6s lipo thats 66,600rpms...
I wouldnt like to run it that fast for any length of time- it works best when used in spec at 4s lipo, and geared accordingly. With a lighter 1/8scale conversion you could gear taller than when using the motor in a 10lb emaxx, but I wouldnt push your luck. |
Ok Ill see what other people have to say.
I think Ill go with the Medusa 36-60 1600kv instead. Same price but alot better.
Thanks DB. I think its the smarter idea of the two also.
| All times are GMT -4. The time now is 03:46 PM. |
