a Few questions as i wait for my monster
hello all first question for 5mm motor shaft does everyone shave a flat spot into it?
i have 3.3 revo conversion RCM motor mount medusa 36-60-2000kv motor 5s1p zippy-h 5000mah batt talon tires 5.75" does all this info look correct i remember looking at an 18 tooth pinion before and only getting 40-45mph which seems to be the best target speed and now i get 50-55 which is prob over geared correct? did i make any mistakes? Differential Ratio: 2.8461538461538463 Transmission Ratio: 2.111111111111111 Other Ratio: 1 Spur Tooth Count: 38 Pinion Tooth Count: 18 Total Voltage: 18.5 Motor KV: 2000 Tire Diameter (inches): 5.75 Tire Ballooning (inches): .4 Motor Current Draw: 0 Motor coil Ω: 0.006 Spur/Pinion Ratio: 2.11 : 1 Total Ratio: 12.68471 : 1 Tire Circumference (inches): 20.58 inches (522.67 mm) Total Motor Speed: 37000 RPM Vehicle Speed: 56.84 mph (91.3 km/h) Estimated Adjusted Speed: 52 mph (84 km/h) - 8% loss Effective KV Value: 2000 KT constant: 0.68 oz-in/A thank you as always jeff |
I grind a small flat spot only as wide as grub screw. Throw it in a sandwich baggie and poke the shaft thru the bag then grab your dermal tool(or go by one) with a fine grinding stone and go to town. or you can use a file but that would blow.
good idea with the sandwich bag i didn't think about shrapnel getting in the motor, and of course i have a dremel, everyone should have one
I just used a dremel to do mine
just curious if this seems to check out for what i have
3.3 revo conversion RCM motor mount medusa 36-60-2000kv motor 5s1p zippy-h 5000mah batt talon tires 5.75" Differential Ratio: 2.8461538461538463 Transmission Ratio: 2.111111111111111 Other Ratio: 1 Spur Tooth Count: 38 Pinion Tooth Count: 18 Total Voltage: 18.5 Motor KV: 2000 Tire Diameter (inches): 5.75 Tire Ballooning (inches): .4 Motor Current Draw: 0 Motor coil Ω: 0.006 Spur/Pinion Ratio: 2.11 : 1 Total Ratio: 12.68471 : 1 Tire Circumference (inches): 20.58 inches (522.67 mm) Total Motor Speed: 37000 RPM Vehicle Speed: 56.84 mph (91.3 km/h) Estimated Adjusted Speed: 52 mph (84 km/h) - 8% loss Effective KV Value: 2000 KT constant: 0.68 oz-in/A does all this info look correct i remember looking at an 18 tooth pinion before and only getting 40-45mph which seems to be the best target speed and now i get 50-55 which is prob over geared correct? peace j |
When you did your earlier calcs., did you enter 4s instead of 5s?
I have a similar setup in my conversion the same pinion/spur but I have the wide ratio gears in the tranny first gear removed. and locked in 2nd gear, FOC...you will soon see the Talon tires suck I now go between Crimefighter LPR and Badlands on Maximizer Beadlocks...it all depends on what I am doing...and my setup is good for mid 50s @ WOT... the rest of my setup is in my sig the Medusa 60 can might get hot in a Revo though ... |
you have a 38t spur gear?...are you sure about that....
i did not know that 40 tooth was stock (bought the truck on ebay), and yes it came to me with a 38t. i can easily buy another gear. would that still be over geared? i looked briefly on the traxxas site and did not find anything bigger than 40t, is there another option. i already have the 18 tooth pinion and was looking for a cheapskate way to lower the speed. i should have double checked Brian g speed calc:lol:
i did not know that 40 tooth was stock (bought the truck on ebay), and yes it came to me with a 38t. i can easily buy another gear. would that still be over geared? i looked briefly on the traxxas site and did not find anything bigger than 40t, is there another option? i already have the 18 tooth pinion and was looking for a cheapskate way to lower the speed. i should have double checked Brian g's speed calc:lol:
revo's came stock with a 38 not a 40.
| All times are GMT -4. The time now is 11:25 PM. |
