help with timing on a Medusa 36-60-2000 v2
I have a Losi 8ight with:
-Esc: CC Mamba max -Motor: Medusa 36-60-2000 v2 -Battery: Polyquest 4S 5000mah -Gearing: 14/48 -CC BEC -RCM battery tray and motormount As the Medusa seems quite simular to the Neu, im woundering about the settings for the timing, should it be "0"? I now have it on default (10) and Punch control at (70) start power is default (Low)..... if i change the timing to 0, should i change something else? like punch control? start power? |
timing at 0?? i thought it was like highest, high, normal, low, lowest.
i always put my to the lowest cause i never raced but those where 9xl motors. |
I run my setups with timing at 0, increasing the timing increases performance with a brushless motor very little, but increases heat alot....its not a good trade off, punch control at 0 and in the Castle SW, I adjust the throttle curve instead of using the punch control |
azjc: thanks for the reply, but what about "start power"? (I just tried to set timing to lowest (0) and all cogging went away)
I am really pleased with my medusa.... i seems to have simular power to the Neu and doesnt run to hot either.... |
I just got my Medusa 36-50-3300 and the instructions (yes I always read them!) say for best efficiency, your esc should be setup with 8-10 degrees advanced. Thoughts?
Interesting find for sure. It would be nice to see it experimented with more to verify the results.
For timing, it's best to go with the manufacturer's recommendations.
Multi-pole motors like more timing than do inrunner 2 pole type motors. There's really no comparison between the two in the timing realm. What applies to one, doesn't necessarily apply to the other. It's not Apples to Apples. |
Found this on Neu's website:
5) For most uses the low advance setting is best—motors have better efficiency. “Y” wind motors can use medium advance for a little more power or speed. “D” wind motors should always use low advance as there is no improvement with higher advance settings. |
| All times are GMT -4. The time now is 05:11 PM. |
