Finally done!
Hi.
Finally i've finished to built my revo conversion. In the first release of my project i've used a VXL system but it died after two weeks for too much KV of the motor in comparison with the weight of my truck. Now i've installed: -MM -Feigao 8XL -rc-monster motor mount -7,5 A ubec -3 30x30 mm brushless fans. The one on the esc is fixed with red silicon (loctite). -3S 4500 Polyquest battery. I've an answer for you. I'm going to remove the first-gear and use the monster with only the second gear. What pinion and spur will you use? http://inlinethumb31.webshots.com/42...600x600Q85.jpg http://inlinethumb23.webshots.com/39...600x600Q85.jpg http://inlinethumb36.webshots.com/42...600x600Q85.jpg |
an 8xl on only 3s? not gonna move that good without biulding heat, should go with 4s
a 9xl on 4s would also be better as far as heat goes Welcome to the forums!!!
Nice paint job on the body...:yes: Welcome to the forums as well....:mdr:
Welcome.
Replace the 3s lipo with a 4s, or 2x 2s wired in series. Use the calculator to determine your gearing, aim for about 35-40mph: http://www.scriptasylum.com/rc_speed/_top_speed.html Just fill in the boxes. |
Great looking Build you have there...
OOOoo yahh Welcome to the team!.. This is great place to spend a few hours on from time to time.. Have a great one and Cool truck.. |
Nice, have you run the truck yet?
| All times are GMT -4. The time now is 02:41 PM. |
